I have a 1986 35 hp Mercury engine I just installed a Tiny Tach on. It show the engine is idled at 1000 rpms. I need to know what the tach should be showing. It came from the manufacturer set at 360 degrees [1 spark per revolution]. I extended the wire lead by about 18 inches with stranded wire and it seems to be working correctly while running the engine on water muffs. I haven't had a chance to try it out on the water yet. Thanks
