hello all.got question for y'all.on sticker on my motor says idle timing is 4 degrees ATDC.i read that is engine warm and in foward gear.originally timing was set at 0 degrees when i checked it at cranking speed with ECM disconnected.i rechecked it later in water to make sure.my problem is it was running real rough just in foward gear.i back it back down to 0.it ran smoother.was wondering if i should put back to 4 degrees ATDC and try raising idle or something or it being at 0 is ok.it says in book 0 to 9 degrees ATDC but on sticker it says 4 ATDC.and i heard to follow sticker if it has one.thanks again in advance.
