OK, I got a new VRO unit, installed it. Went to the library and got a manual to correctly install it. If I push in the key about every 10 seconds it will keep running. When I put it in gear and throttle up, it will run for about 10 or 15 seconds then die.
All these problems started 2 weeks ago when my kid took my fuel can and filled it with gas and the can had water in it. I rebuilt the carbs, replaced the fuel filter, lines and bulb. I drained the main tank, replaced with fresh fuel from a new fuel can, and put one bottle of ISO HEET in the fuel to insure the water was removed.
For the life of me I can't figure this out. Could there still be water in the fuel that I may have missed?
