tfbrown1270
- Sep 5, 2003
- 202
Hi.
I have a new to me 20 hp Evinrude, and am trying to figure out the year etc right now on another post but in the meantime I thought I would address another issue...
It starts OK, runs pretty smooth except for an occasional hic-up and moderate rpm except when I idle it down to minimum (as though to slow troll) it sneezes and quits....so trying to be procative I decarbed it and that made it run smoother at the higher rpms but no differance at idle. I pulled the plugs and they look OK; wet and oily with black on the protruding tip thing (I could get the plug #'s if need be but I remember they are Chanpions and they are gapped to .034). The bulb stays hard while running and the compression is 105 (top) 110 (bottom) when warm, oh that brings up something..I let it run for over an hour to get it hot but it never got above luke warm. I could hold my hand on the head for 20 minutes if I wanted to...I have not taken apart the carb but will if necessary if thats the problem..thanks,,
