Idles, no power
yamjer
Hello all. I have a 1988 doral with a 350 mercruiser 260 hp engine. I was motoring to my slip and out of the blue I lost my speed. Limped to slip. I have what seems like a knocking/clacking sound from motor. I pulled valve covers and reseated all. Noise still there. Took boat for short run (3/4 minutes) and could not gain any speed. Is my crank gone? Bearings? Is there any way to check without pulling motor?
alldodge
If it's banging like a hammer then most likely it spun a rod bearing
What does this mean? reseated all
Could do a compression test to find out if it might be a valve issue
yamjer
The noise sounded like a valve problem. Took valve covers off, removed rockers and rods to check if any bent or loose. Put back together. None of the rods are bent. I also think bearing but not sure I'm up for the challenge.
alldodge
There are some you tube vids that has the sound of a rod knocking
Again, if you have good compression then it's not a valve
Ayuh,..... I wouldn't discount a drive problem either,.....
yamjer
I was ready to change my outdrive (I have a couple in my garage) but the noise from my motor were edging me to think that was my problem. Thanks for responding.
ROY WILLIAMS
did the engine oil ? 40wt , 20w-40wt ...Mercruiser engine oil .
yamjer
Did compression test. #1 -145 #2-90
#3- 65. #4-135
#5-50. #6-65
#7-135. #8-135
Would think head gasket port side but geez not sure what to make of these. Will bring a turkey baster and try and inject a tbsp of oil for another round of compression tests.
#3- 65. #4-135
#5-50. #6-65
#7-135. #8-135
Ayuh,..... Pull the motor,...... You've got serious problems,......
Or do a leak-down test to see whether it's rings or valves,....
yamjer
Since its almost end of season here, will try leak down test. But I agree. I will probably be looking for a motor.
ROY WILLIAMS
#3- 65. #4-135
#5-50. #6-65
#7-135. #8-135
the flat taps .... the gasoline higher and the adjusting it timing ....
I was the marvel mystery oil in the fall spark plugs out one OZ. did the winter maintenance . did the rusted combustion area MMO .....
#3- 65. #4-135
#5-50. #6-65
#7-135. #8-135
since 150 psi is a new motor
you have 4 pistons trying their best at 90% power and 4 pistons that are simply causing drag.
great opportunity to build a 377 or 383 since it looks like you need a new motor.
tank1949
If by "reseating," you meant adjusted volves then do compression test to pinpoint area. Examine plugs. If rust or water, you may have to tear motor apart and buy new exhaust manifolds or risers. However, you may have spun a bearing.
tank1949
#3- 65. #4-135
#5-50. #6-65
#7-135. #8-135
I had a compression tester malfunction on me one time. Get a second tester and see if readings are the same. If so I expect you will have to repower. If salt used, replace block.
