Idles up in reverse
kucobra
I have a 1978 70 hp Merc w/ pwr TNT. It goes into forward no problem, It will go into reverse but as soon as it engages the motor will suddenly rev quite a bit causing the the boat to lurch backwards. It will continue until you go back into neutral. It really revs quite a bit to the point of raising the motor. I've never seen this before, any suggestions appreciated.
Laddies
Banned
Re: Idles up in reverse
Either the shift cable needs adjustment of the reverse shift lock cam is bad maybe both
fishdog4449
Adjust shift cables; It is adjusted wrong so that when you pull the lever back to engage reverse, it engages the throttle prematurely. The motor shouldn't raise just by goign into reverse, that seems to be a whole other problem. You should have the reverse lock (if there is one) engaged.
kucobra
OK Ill have the cables adjusted. The raising part is because motor is unlocked. (lake I fish is full of stumps)
thanks
Laddies
Banned
When everything is working right on your engine it should be locked down in forward and neutral and release as it is shifted in to forward, if you have removed the tilt pin or wedged the reverse lock that will cause shifting problems all by it's self
Chris1956
There should not be a mechanical reverse lock on that motor. When the PTT is installed, the reverse lock is no longer necessary. You should use the tilt pin to protect the transom from being gouged by the motor.
