Idling problem
I have a 1985 Mercruiser (GM) 140 and have been at it for 2 months now and finally got it in the water.Problem is when sitiing at idle it revs up and then slows down to a near stop then revs again.I t has not been run for a couiple of years.New fuel,plugs points, tried carb cleaner but no joy.
Any suggestions ???
Re: Idling problem
Ayuh,... Sounds like it might need a carb Rebuild...
JustJason
Re: Idling problem
Check the intake, carb base, and throttle shaft with some foaming oil for an air leak.
If you don't find one then its probably time for a carb rebuild.
Top of the morning to ya Bond-o
Re: Idling problem
Ayuh,... Right back at ya Jason,... Just about to sign off,+ head out the door to go to Work....;)
Re: Idling problem
Hi..thanks very much for the advice.Guess my first try will be the foamin stuff and then learn how to rebuild a carb.....always somethin new to learn.
