I have a 99 model Mercury force outboard motor. I have had it worked on a couple of times but I keep having a problem with it not wanting to idle. Sometimes it runs fine after I get it on the water but after being on the water a while it will start to die every time I let it idle. It also does not crank smoothly but it is a 99 model so that could be just be normal because of the age. Is there anything I can do for this issue?
