Hi all, my boat, a 1974 19' Neptune with a GM 250 inline six and an electric shift sterndrive, came with two props. The prop that was on the drive when I bought it is marked "14 1/4 10". Another prop that I found in the boat is marked "14 14". I'm guessing that the first number is the size, since on the 14 1/4 prop the body loks a little larger, and that the second number is the pitch. I never really thought much about it until reading about prop selection here. I don't pull skiers, and spend most of my time cruising from one fishing spot to the next, so lower cruising rpm's sounds good to me. Should I be concerned with the first number, which I took to be the size? Both props fit on the shaft just fine. Thanks for any help.
