Hi all,
I have a 25 ft Donzi with a new 350 and Cobra outdrve. Long story short the guy I bought it from had replaced the outdrive with a used one he bought from someone.
I looked up the info on this drive from the info on the tag on it.
Model 985271
Engine 5.0
Serial T0566515
In my manual it says that that model # was used in 88 on 5.0 engines and has a 1.50:1 gear ratio. It also says that the 5.7 had a gear ratio of 1.41:1
BUT it lists a couple other years that have the 1.50:1 gear ratio listed on 5.7's.
At WOT I only get about 4200 RPM and I already have a 15 pitch prop on. (came with boat). I found out that the original prop that came with the boat new was a 19 pitch prop.
So my question is, If I increase the pitch to say a 19 pitch or 21 pitch prop, will the RPM still go down as I have a gear ratio that (maybe) preventing it from reaching the correct RPM in the first place?
My reasoning in thinking this is that the engine can and is supposed to push a 19 pitch prop to 46-4800 RPM at WOT. But because I have a different gear ratio it is preventing it from pushing the 15 pitch one past 4200 RPM at WOT. So with a bigger pitch prop on it should still have the power to push to 4200 RPM???
Am I thinking right or am I wrong?
Thanks
Model 985271
Engine 5.0
Serial T0566515
Thanks
