? if johnson 9.5 HP MO or MQ-12A has a water pump?
jpettit
I am not seeing anywhere for water to eject from on hood of motor?
please help Son is pumped to try out but I do not want to cause harm to motor as I saw no water coming out with the hose attachment connected.
thank you
Jon
You can not run that motor on a regular hose attachment !!!---------The water pump is located above the lower unit.----------You remove the 4 screws and seperate the lower unit.----------The shift connecter then becomes visible.---You must REMOVE one screws to drop the lower unit.------------This motor needs a new impeller now.
jpettit
thanks for info do you know where I might buy an impeller & how difficult it is to install?
pretty green here on motors.
again thanks for info
& to run it I need to do so in a tub or container of water?
Most BRP / Evinrude dealers would have that item in stock.----Impeller is straight forward " nuts and bolts " type work.--You must run that motor with water level 6" above the pump !
