I've seen more engines destroyed because people are to cheap to change exhaust manifold/ risers as a preventative action. especially raw water cooled engines. They start to clog and overheat. once one side overheat it makes steam and it has enough pressure to push the water completely out of the engine. Then something cracks, It cools off enough to get it started, and water starts going where it has no business being.
if your lucky it's in the crank case, but your luck may just get you back to the dock.
If not it's in the cylinders , and we all know how much fun it is to pull spark plugs on an omc and your calling sea tow. either way the $500 for new exhaust every 4 or 5 years now turns into thousands.
If you just bought a new to you boat.or if you cant remember when you changed them. Change em now. If your running warm above 2800 rpm it's time. It really sucks overheating with your family and friends aboard. P.M. is the key to reliability.
Just my 2 cent.
Just my 2 cent.
