NPS350
- Aug 24, 2020
- 3
I’ve searched the internet for a Johnson/Evinrude 0584451 ignition coil (9.9 HP 4-Stroke Johnson) with no luck.
My question, the Johnson 0583740 coil is also a duel coil, but it has duel primary terminal instead of the single terminal post on the 5884451. I’m wondering if I spliced another wire onto the current single terminal wire and then connected the wires to both 583740 terminals if it would work as a replacement coil?
