Ignition conversion
Jdwardus
Is it possible to take a 1975 650 mercury with a distributor. And convert it over with a newer ignition. With the trigger under the flywheel. Would the trigger housing and seal from a newer engine work on the older engine. Any ideas anyone
Jdwardus
What can be done or has been done to upgrade this ignition system to cheaper components
matt167
You could modify a distributor from something else, but being 3cyl, it's kinda limited.. Geo Metro comes to mind as possible.. Bigger project though as it's converting to battery ignition
