Thatoneguy
- Jun 2, 2016
- 3
The ignition fuse on my 2002 Glastron SX175 with a 3.0 Volvo Pentax GSM-B continues to blow on me. This first happened last weekend about 30 seconds after starting up the motor. After replacing the fuse and starting it again, everything was fine and the boat went about 400 ft before everything shut off; blown fuse again.
After getting it back to the lift I checked all the wires but haven't been able to find anything where a short could be occurring. There was corrosion on the starter so I cleaned it up. I tested it after the clean up and it ran fine for almost ten minutes until I took off to get on plane. I tried to see if a new fuse would get me back to the dock but the fuse went as soon as I turned the key to run.
As a little background, I recently replaced the u joint bellows and gimbal bearing because I had taken on a lot of water the weekend before. The boat is new to me and it appears that the bellows were neglected. The water had filled the bilge about to the bottom of battery. I'm wondering if the water could have caused an issue with the starter or the starter solenoid.
As I stated, there is no obvious short under the dash, by the engine, or the throttle control. I do have a multimeter but I'm unsure of where to start in my search for the root cause. Any help is greatly appreciated. Thanks in advance!
