Hi all, I'm having some weird issues starting a Mercruiser 3.0L recently. Whenever I try to start the engine it blows the 10 AMP ignition fuse after 2-3 seconds. Starter turns 1-2 times then the fuse blows.
I thought I have a bad ignition switch so I've replaced that, but that didn't fix it.
With the key ON everything else seems to work - blower, bilge pump, gauges light up, trim/tilt, etc.
Any other ideas on what I should check next?
