ignition is dead
jonz
I was testing my fuel gauge put wire on purple wire on gauge and grounded it on fuse bus now I get nothing on any of the gauges and ignition will not crank engine and the boat ran fine last week did I fry computer. I checked all fuses on fuse block and there good are there any fuses in engine compartment the motor is Volvo pent a 1996 5.0fi ?.don't know were to start , can any one help thanks in advance
Silvertip
Re: ignition is dead
1) The purple wire on the fuel gauge has +12 volts on it. When you touched a wire to it and ground you created a short circuit just like sticking a bobby pin into a wall outlet at home. Don't do that any more.
2) Yes -- you blew a fuse or popped a breaker in the engine compartment. If you don't know where they are, this would be a good time to download a diagram for your drive and get familiar with where stuff like this is located and having spares on board. A 50 cent fuse or being able to locate a breaker and push the button is a heck of a lot cheaper than a tow and trip to a shop.
jonz
Silvertip thank you for the info . I can't believe what a bone headed move I made. Does any one know were the fuse on the engine I need to look for its Volvo pent a 5.0 fi ( ford) 302 1996 I see brakers on fuel pump and on top by silinoid.
Ayuh,... Push 'em Both, 'n try it...
Don S
There should be a 20A fuse under the helm in the red wire coming from the engine harness to the ignition switch B terminal.
Item 24 in this diagram
jonz
Thanks guys I found that fuse, 20 a just like don said. For sume reason I'm not getting power to fuel pump it will crank and crank pulled fuel line no fuel check with ignition turned on no power to the wires at fuel pump. I've push breaker any I'm getting power on both sides of breaker. I'm stuck is there a fuse I'm missing..... thanks in advance for any help.. jonz
Don S
What is the FULL model number of your engine? The serial number may help also.
I will be moving this over to the Volvo forum, it it's working.
jonz
Don , is 5.0fi has sx c1 cobra stern drive is that the full # 1996 302 ford
Don S
The NC is the part I needed. When you first turn the igntion switch on, do you hear the fuel pumps run for 2 seconds then shut off?
There are several different circuit breakers on the engine.
jonz
[not sure what NC stands for] Don, yes i do here a sound from the engine when i turn ignition on for a few seconds then i stops, i checked to see if the tank is plugged by using a squeeze ball on the fuel line and i get fuel. thanks Jonz
Don S
If you can hear the pump come on for 2 seconds, then it works. I doubt your fuel tank plugged up while you tried fixing your fuel gauge and blew the fuse, perhaps you need to explain exactly what your problem is.
jonz
Hi Don, before I tried to fix fuel gauge I when to the bay and it would,t start. I took off fuel line because it seemed like no fuel was getting to engine the boat ran perfect last week. In between the last time I ran it I put new stereo in and I bumped the hot lead that powers stereo . Could that of caused some sort of problem? Everything else is working properly. I tested the two wires that go to pump with ignition on and no power. Is that normal. Could the relay be bad. I'm lost don,t know were to go from here. Thanks jonz
Don S
Sounds to me like you need to start disconnecting the battery when working on things.
If the engine cranks over with the starter, check for spark from the coil.
jonz
Don, I,ll check for spark..your right aboat that I guess that's why its all ways the first thing in the instructions . I hope I learn my lesson. Could I have fried something that is going to cost me alota cash? Hopefully not... jonz
jonz
hey Don, i was at work today think it my be the relay on the pump and did my research on relays because i was not getting power to the fuel pump. put a new relay in and it fired right up will test old relay at work tomorrow with mechanic , to make sure that was the problem that was to easy , do relays act up some times? well any ways thats for all your help really appreciated.. question what the best manual to buy for volvo pent, thanks jonz
Don S
Sure, It's called an intermittent problem. Corrosion can do it, a faulty relay could do it.
It's working now, that's a good thing. I wonder how long that will last?
