Re: Ignition Key On Dashboard and/or Control Box
The dealer did the easy work around instead of replacing the controls (OMC changed wiring harness design in 1996) they mounted a key in the dash. You should be able to rewire your existing controls with the dash switch. I assume the old wiring harness with the big red plug is still attached to your controls. If it is it will need to be removed as none of that wiring is required as your outboard uses the modular connectors. Your other choice would be to find a set of 1996 or newer controls.
Thanks for the input!
I think it is likely that the control box was existing when the previous owner re-powered with the 1997 motor. The dealer (probably) just wired for the new motor and left control linkage be.
I will have to see if the big red plug is in use at all. If my assumption above is true, it should not be. I just got the hull yesterday and have yet to get "upsidown" inside to see what is really what.......
BTW, If you know where to find an Operators Manual for this motor, please let me know.
Thanks,
-Todd
