Ignition kill switch
tpenfield
Four Winns Horizon? Got picture of the kill switch?
start googling pictures of ignition safety switches to see what was used.
what is the issue you are having?
Coosy122
I tried to upload a pic but it says invalid file data. Its a jpg picture file.
Coosy122
it may have been too large. Smaller pic attached.
Coosy122
back has two female connections. I should have disconnected it for pictures...
Coosy122
I believe the switch or connection has a short. I would like to order a replacement or replace with a universal switch.
tpenfield
pictures are kind of dark . . . so I lighten it for you . . . Looks pretty standard.
tpenfield
It is the universal kill switch where the clip holds the switch plunger IN. The other kind has a more flat looking clip that holds the switch plunger OUT.
Any boat store or online source should have both of these types.
not to mention if you pull the panel, you can read the manufacturer and part number.
you are supposed to have a short in it when it is depressed like it is. the two contacts are held together with the clip, then when you pull the clip, the contacts open, breaking the connection to the ignition on the engine.
if you think its the kill switch, simply tie the two wires together with a jumper wire. this will bypass the kill switch. that will let you know if you have the right problem part or not.
