socalboataddict
- May 30, 2005
- 44
specs: 1993/94 90HP mercury outboard bearing serial # od205997. <br /><br />im fairly new to boating but thanks to this board, my learing curve is way up.<br /><br />my o/b won't start and here is what I did to troubleshoot.<br /><br />made sure I had fresh fuel. Checked - lots of fuel leaked out of the carb when I tilted the motor up all the way. <br /><br />next I checked for spark. <br /><br />no spark in cylinder # 1<br />little or no spark in cylinder # 2 <br />did not check cylinder # 3. <br /><br />I can really use some guidance as to what to check or do next. <br /><br />should I change the CDI switch box? where is it located? <br /><br />thanks folks in advance for reading this. <br /><br />Jon
