I will try and be brief and to the point
I found spark in only one cylinder
Found corroded and broken wires on trigger so replaced
still only one cylinder sparking
found trigger only coming from middle post of ignition module
switched trigger wires and coil wires around and found that only spark would come out of middle post
replaced module.
low spark all cylinders
frustrated left battery charger on for about an hour
for giggles hit starter and it fired up
put muffs on and it ran great for 10-15 minutes.
took to the lake and it wouldn't run
no dva but checked resistance of stator and found out of spec, (can't remember specs or reading but out)
contemplating replacing stator and or rectifier
I figure I would ask before buying for information or things to check. Thanks in advance!
replaced module.
