Ignition problem?
floryj
I have a 1994 Mariner 125. Soon as I give it juice by turning on the battery, it tries to start even without the key. I hit the kill switch and it continues to attempt to start. I then select off on the battery selector and it stops. Is this a problem with my ignition switch? Thanks.<br /><br />Jesse
Laddies
Banned
Re: Ignition problem?
The problem is in the starter cicurt first disconnect the small yellow red wire from the solinoid and try the battery back on, if it still trys to turn over it's the solonoid, if it doesn't it's in the switch or wiring to the switch
floryj
Hi, thanks. Problem was the solonoid. Good advice<br /><br />Jesse
