ignition problem
d absher
when i ajusted the idol screws on my 1973 85 hp chrysler i went the wrong way the motor idoled faster than it should
when i turned the key off the motor kept running i had to turn idol screws all the way in to kill the motor now i have no spark this motor has magnapower ignition also not sure if this motor has points any info wouild be helpfull thanks
jerryjerry05
Davetward
Re: ignition problem
I have been working on a friends Chrysler 75 that had no spark. It had a CDI box and gapless plugs. After doing much research i found out that these CDI packs are not very reliable and can be expensive. If the engine is turned over with the plugs disconnected / not grounded they blow. In short I replaced the box with an old style automotive coil and condenser. Now there is a strong reliable, testable spark. Try this link for the details
http://www.smokstak.com/forum/showthread.php?t=52047
There is an excellent 'how to' re carb adjustment / setting under the FAQ section on this forum.
