shane hawkins
- Apr 7, 2010
- 27
Just bought boat, replaced plugs with ngk's cap rotor etc... Problem is really hard to start, not sure if im setting choke properly or what, i have herd that cracking the throttle once should set it. Took it to the lake today got there and it wouldnt start, after getting it back home i found that shes getting no spark, coil wires have 10v with ignition on but as soon as i turn it over it grounds and the second you let off the ignition it goes back to 10v and trys to run? Ign switch? Also checked timing yesterday when i tryed to jump the spark advance with a wire nothing happened? Once it seems to catch when letting off ignition it runs great! I have downloaded the manual for this boat and it says to check resistance from coil to ground bracket and it should be infinate but i get nothing, it does read 0.4 ohms when jumping terminals as its suppose to. The exact same thing goes for the pick up. There is no kill switch.
