barnstormerj
- Jun 13, 2011
- 33
Looking at this distributor, it has points, looked up tune up specs in climber manual, two chapters have different tune up specs, one says base timing at idle is 6 deg before tdc, the other says one degree before? prestolite distributor. Also, points are burned, had msd destributor, no resistor wire, but I think it is a 12 volt coil., so this may be ok? any advice for the timing and the balast resistor, Help!
