Wonbigfish
- Apr 29, 2013
- 36
I have a 98 Palm Beach 16.5 ft with a 90 HP Force Outboard. I recently replaced a voltage regulator & igition switch. Last trip out the kill circuit was malfuctioning so I disconnected it at the voltage regulator and run a temp wire to shut motor off. We also had a shock condition where as the kill switch would zap you. We then noticed we were getting shocked if the floor of the boat was wet. Note it was salt water & it can carry a current easier than fresh water. My thinking was it had to be an issue with ignition switch I installed several months ago. I removed it from the dash & then removed the black tape I put around the heat shrink butt connectors used on initial install. I then reconnected the kill circuit wire & kill switch. To my surprise the electricutions quit and boat ran good. But I noticed at low idle it sometimes ran rough and clear up above idle. Can anyone point me in a direction that might repair my condition. I sure it's liable to return.
Wonbigfish
Wonbigfish
