Ignition/Spark Plug wires?
palace
Is there any difference between electric ignition and standard (point) spark plug wires? Could you use so called electric ignition wires with a point/standard system? and vise a versa? Just as long as they are marine/solid copper wire?
RogersJetboat454
Re: Ignition/Spark Plug wires?
Not one bit of difference between the two.
Ayuh,.... Never seen Solid Copper marine spark plug wires.... Not in 20 years or more....
Boats run the same wires as cars or trucks,....
'cept the Ends gotta fit the application....
palace
Thanks
What is it with the ends?
Thanks
Ayuh,... Ya gotta know where, 'n if, ya need innies, or outies, angled, straight, or 90?ed....
'n the various different lengths,...
generally boat wires are longer than automotive...
perna00
I've heard a few people say that you can also use stranded wires off of automotive use if you use grease on the ends. . is this true?
