Hi guys,
'74 inline 6 165 with 165 outdrive.
So I got the boat out to start getting it ready for the summer and had some funny issues come up. First, I think my ignition switch is bad. After I ran it on the muffs I went to kill it and when I pulled the key out the engine just kept running
. I had to pull the coil plug to get it to stop. Also when I hook the battery up the coil get extremely hot even without the ignition on. The lights on my gauges also comes on.
Next, when I checked the shifting it went into forward fine but it doesn't go into reverse until I'm starting to get into the throttle. Is there some kind of adjustment on the shift cable?
I need a brass drain plug on the exhaust manifold. I picked up a 1/4" NPT brass plug but it's too big. Does anyone know off their head what size it is?
Finally, when my RPMs approach about 2800 my water temp. gauge will fall back to the bottom peg. Once I let it back down to 2500 or so the needle starts registering again. I didn't push the engine any higher to see if the needle would come back but I thought that was strange.
While I have you here, when I try to trim the O/D up the pump will just click. The drive is all the way down but when I push the down button nothing happens. I haven't checked the fluid yet so I'm sure that's the problem. I just wanted to throw it out there to see if something else might be up.
Every one of these issues was not present last year when I put it up. Maybe I should just keep using it year around.
