Ignition Switch for XR6
Dukedog
most are pretty generic from way back when.. prefer oem... jus wanna solder and heat shrink all connections... you'll be way ahead down tha road... jmo.
Knottymate
A Sierra MP 5200 was suggested. Is there an OEM part number available or is the Sierra OK?
Dukedog
after market will probably be of if ya solder and heat shrink also... one oem number, 87-88107A5, sure there are more....
Knottymate
Thanks for the response. Believe found a switch with no lead out wires to solder. My switch has 6 direct terminal screw in receptors
The Teleflex Ignition switch by Sierra part number MP56472 had those screw in terminals.
