1976 Evinrude 70 hp
Turn the key and just barely hear the solenoid click.
As per the service manual everything passes until step 3 & 4
With key is start position and test the "S" terminal , I`m getting 5.7 volts (step 3) it says if no reading go to step 4. Should that be 0 volts or the 5.7 volts?
With key in start position and test the (B) battery terminal I get 12 volts...if it does this it says the switch it bad
Tying to figure out if its the ignition switch or neutral safety switch.........just need someone to check my work before throwing money at it.
