ignition switch wiring 110hp merc
Scott Proffitt
old ignition switch was corroded-it is labeled INDAK - it has 5 terminals on it, with 6 wires<br /><br />F - 2 white wires, 1 going to button for choke<br />D - 1 black wire<br />A - 1 red wire<br />E - 1 pink or orange wire<br />B - 1 yellow wire<br /><br />the new (used) switch given to me has only 4 terminals on it<br /><br />A, B, C, & I<br /><br />wanting to know how to wire it, if possible<br /><br />the switches are both 3 position, on off start<br /><br />???also, how can I find out the age of this engine???
corm
Re: ignition switch wiring 110hp merc
the motor is a 66 or 67SS and the switch is not interchangable. If you lost a key the key number is on the switch like 102 or 105. They can be ordered.
