Hey all, I have some issues happening with my ignition.
1977-78 not sure Evinrude 85 HP.
The boat worked just fine recently. I have been working to fix some issues as the lights and such were not working in the gauges. I found that it was due to a faulty headlight switch. I have a purple wire that I taped into to get "ignition on" power to the gauges. I noticed that all of a sudden that wire no longer had power. And also when I turn the key the motor will not crank. When I give the purple wire to the ignition switch power it cranks over just fine. Any ideas on how to trouble shoot this? I was thinking that the ignition switch should get power from the selenoid but all of the wires go into a harness that goes to the engine.. Any help would be greatly appreciated. Thanks.
