Ignition wiring on force 50
This is my wiring diagram. And I bought an aftermarket ignition switch. Choke and start work and cranks over but no spark. Next post has picture of switch diagram I bought.
Nordin
Please you have to give more information about your engine.
Year, model number, ignition system.
Does it have battery ignition system with points, magneto with points or magneto CDI without points.
jerryjerry05
Like Nordin suggested, Model/Year/Serial#
There are at least 2 different keys used on the 50
[No message]
Nordin
Disconnect the black/yellow from keyswitch at terminal strip (white) and leave it unhooked but insulate it.
The white at terminal strip is minus (points) to coil #1.
I think you grounding out the coils with that one.
