ignition wiring
i have a 1977 70hp johnson. i cant figure out which wires go to which points on the ignition switch. it has a red(battery), white?, black with yellow stripe?, pink?, purple with white stripe?, grey?, black?, and purple. also how do the battery cables connect to the solanoid?
Thalasso
BBATTERYRed with Violet stripeBattery positive via fuse
A or IACCESSORY or IGNITIONVioletAccessory loads; engine ignition
SSTARTYellow with Red stripeEngine starter solenoid coil
CCHOKEViolet with White stripeEngine primer solenoid coil
M (raised)MAGNETOBlack with Yellow stripeEngine ignition kill circuit
MMAGNETOBlackEngine chassis or battery negativehttp://continuouswave.com/whaler/ref...ionSwitch.html
