IL6 Timing 1972 1150
stant1man
I stupidly unbolted my flywheel from the timing belt sprocket and im not sure if i put it back correctly. Is there a way to check?<br /><br />There doesn't appear to be any timing marks on the flywheel anyway so , having now replaced my timing belt. Is there a way to tell how to time it without the flywheel marks?<br /><br /><br />Stan :confused:
Laddies
Banned
Re: IL6 Timing 1972 1150
Look on the out side of the flywheel there should be 3 punch mark on the vertical surface, put a pencil down number one cyl and roll it to TDC and alingen with the short mark on the flywheel cover
stant1man
Thanks Laddies, when you refer to the flywheel cover do you mean the aluminium cowel?<br /><br />Kind Regards<br /><br /><br />Stan
