ilde speed
mobeytyres
hi first time out on boad and noticed that the idle speed seemed very low on my evinrude 50 (1976ish) does anybody no the idle speed setting for this engine any help with this engine would be great thanks
mobeytyres
Re: ilde speed
thanks for that when you say in gear is that in forward at the very first part after neutral as you can tell am very new to all this
mobeytyres
Re: ilde speed
thanks for that have checked it and it was down abit(500ish) is there any way of adjusting it or is it by turning the little black lugs if so which one do i turn the acc or the other which i think is connected to the leaver that i pull up to start it with yhanks again for all your help
emdsapmgr
Re: ilde speed
The adjustment is on the spark advance lever on the engine. Take the cowling off. Have someone move the throttle back and forth. The throttle linkage is connected to the advance lever. Note the position of the advance lever at idle. The screw in the lever adjusts the idle timing. Screw clockwise, and the idle timing will advance, bringing up the idle speed.
mobeytyres
Re: ilde speed
cool thanks for that is there anyway i can do it running in boat yard with water running through engine if so what would the idle speed be then the only reason im asking as im a little worried i may get it wrong and end up with a motor that dont start in the middle of the water <br />is ther any where i can see some pics of where this idle screw is
ezeke
Re: ilde speed
You can tie it to a dock or run it on the trailer at idle speed.<br /><br />Go to the BRP parts diagrams for Evinrude, 1975, 50HP. Crankcase diagram part 51:<br /><br /> BRP Digrams
wilde1j
Re: ilde speed
You don't want to mess with the timing screw, ONLY the idle speed screw ... follow ezeke sugestions for doing it w/o the boat moving.
mobeytyres
Re: ilde speed
had alook today i found a screw that goes back and forwards when i pull the cold start leaver up it that the idle speed screw or am i looking at another screw and would it be nearer the the flywheel
ezeke
Re: ilde speed
Screw is on the engine, if you can't get to the diagram, wait until someone can post a picture for you. If you turn the wrong screw you will make a mess.
