I'm really stumped
Orlando
1996 200 Merc EFI. Trim gauge quit registering right so I took sending unit off and it turned hard so I figured it was bad. I replaced with new unit and still no go. In any motor position gauge reads down, if I remove the ground wire guage reads full up. If I remove the sending unit and leave ground attached and turn tab by hand it will make the gauge read up and down, but when I go to remount the sending unit the tab won't line up. Iv'e tried turning it 180 degrees and it's still off. It;s almost like the pivot that has the key that the sending unit goes into has turned. Is this possible? Any help is appreciated. Thanks
achris
More fish than mountain goat
Re: I'm really stumped
Check for a problem in the wire from the sender to the gauge. Specifically, look for it to be chaffed bare and shorting to ground.<br /><br />Try marking the postition of the key-way and then trimming the engine. Makes sure it's moving relative to the housing.<br /><br />Chris..........
