I noticed that no water was squirting form the outboard engine (Merc. 200hp) when I started up and was in the marina- I never got past low idle speed- every once in a while I noticed water coming out- then would stop- sounds like an impeller problem- I heard the buzzer go off- didn't know what it was. (Not as much of a buzz- more like a solid high-pitched tone- it may even had been my fishfinder reading the bottom?) I shut down the engine. Since I didn't know what it was- I started it again to go back to my trailer- over all I was out maybe twenty minutes or so- never went fast- when the buzzer went off I would shut down. I idled back to the trailer and took the boat out- then I read somewhere about scored cylinders and the like- also about the buzzer- wht are the chances of my doing damage to the engine- especially if I never went over 5 mph? How would I know if I hurt a cylinder-compression test??<br />Thanks and I'm worried- hopefully I'll get good news from someone!
