Just changed the impeller and now I notice water coming from new locations. I am not sure if this is ok and just seeing it now because of the added water pressure and this is from pressure relieve while at 1500 rpm high idle or if there is a problem.
Water now coming from hole in lu where the speedo tube comes out from LU too the speedo. Water also running down outside of lower cover on LU.
By the way I did remove the LU and everything looked fine ran it again and things are the same. Ran the boat and good pressure and no over heat
