fordman49450
- Apr 9, 2005
- 12
ok, heres the story, got a 8HP chrysler outboard from a friend, I traded him 15HP because I wanted something a little more managable for my boat.. Anyways, I went to take it out today, it started great got half way across the lake and she started bogging down, and eventually died. pulled the cover and the head was discolored, and of course it was overheated. tore it down and the impeller was in pieces and the head gasket was blown for both cylinders from the cylinder to the water ports. I was wondering how much damage can be done to an impeller by starting it out of water? I did do this and wondered if this is what destroyed it because I knew the engine was fine last year when the last owner used it. also, inspected the cylinder walls and such and dont see any obvious damage, what damage do you think I could have done that is not visible with a glance? thank you for your time.
