Impeller direction alpha one gen one
Jaysalman
Just removed my impeller for the lower unit I’m trying to figure out wich way the new impeller goes into the housing I did research online and most people say to put it in counterclockwise, but my old one shows that it’s spinning clockwise (check picture) what is the right way?????
achris
More fish than mountain goat
Impeller rotates clockwise as viewed from above.
Doesn't really matter which way you put it in, once the engine's running, it'll sort itself out.
Bt Doctur
in your pic the impeller rotation is CCW so wet it, and twist/push down CCW. I try to set the keyway slot straight ahead
