impeller direction
please help. i have a mercruiser R sterndrive. i was going to install a water pump kit but when i removed the upper housing the impeller fell out when it cleared the shaft and now i do now i do not know which way to clock it in for instalation. thanks for any help.
alldodge
Looking down at the pump, the impeller will turn clockwise
achris
More fish than mountain goat
If you're putting a new impeller in, it doesn't really matter if you get it wrong. Once you start the engine, the blades will flip over to the right way...
The way I do it... Put the housing in your left hand. Then with your right hand, wind the impeller anti-clockwise as you push it into the housing. Using a VERY thin smear of grease in the housing helps. ;)
Chris.....
