Impeller Failure Help
Alfonso52
I am having early outboard impeller failure I suspect comes from sitting 6 months unused thru hot FL summer.
Any suggestions for putting the outboard to bed or starting after 6 months to improve impeller life?
THANKS!
mike_i
If you're unsure of the current condition of the impeller change it out. I've been told by a mechanic to run the motor every once in awhile to keep the impeller wet and flexible and to prevent it from drying out.
Impeller should last at least about 5 years.----Are you using factory parts ??-----Running the motor dry at any time ?----Running in a test bucket the water should be 6" above the impeller.
