had my prop shaft straightened at a local shop a couple of months ago, haven't used the boat since. Went to winterize it today and no output from the pee hole and not a whole lot from around the prop. Shut it down, took water pump apart and the impeller fins were all completely torn off (not melted) at where the rubber fin meets the impeller.
The only thing I can think of is that when they reassembled it they had the fins pointing the wrong way inside the pump, and they tore off on start up could there be any other reason?
