seawallkid
- Mar 16, 2006
- 7
Went to replace my impeller ( alpha one gen 11 ) two of the four water pump housing bolts broke. Then of course I drilled them and tried using a easy out to remove and the easy out broke in the bolt. I am going to drill and tap two new bolt holes. My question is, the bolts are not stainless so I am thinking replace them with stainless. Is there a reason they are not? What should I use for the new bolts???
