Impeller key or pin Johnson 4 hp 1985
MudMullet
I finally got my old impeller off, last night, but it seems I may have lost my impeller key. Im wondering whether anyone can tell me what too look for as I scour the shop floor.<br /><br />The shaft has a notch cut out of it, about 1/2 in lon and maybe 1/8" deep, like a half moon. The impeller has a half-round notch cut into it, running parallel to the shaft. <br /><br />I found a pin taht fits into the channel in the impeller but i cannot find any half-moon shaped piece. <br /><br />My manual, I believe, refers to an "impeller pin" and makes no mention of an "impeller key". If I put the pin in place, it holds the impeller in place, but the impeller has play, back and forth.<br /><br />Should there be another piece to hold the impeller in place, or is the pin all that this impeller is supposed to have?
Xcusme
Re: Impeller key or pin Johnson 4 hp 1985
"Should there be another piece to hold the impeller in place, or is the pin all that this impeller is supposed to have?"<br /><br />Nope, what you have it all to there is to it. The 'impeller pin' resembles a solid roll pin or needle bearing pin. This roll pin fits into the impellor half-round notch. The extra back and forth play is normal. Since the impeller is turning only one way while driven , it's not a problem.
codfather
hi mud just got johnson 4hp not pumping water were can i locate the impeller with thanks codfather
