Impeller not pumping - possible air leak(with picture)
SC_Regal
I searched and could not find a similar problem.
I have an Alpha I Gen II outdrive on a 2000 Regal that I operate mostly in salt water.
I changed the impeller (did not look bad) because I wasn't getting flow through the intake hose at the t-stat. With the new impeller - same result so I just removed the lower housing again, backflushed everything to be safe, made sure the tubes had been properly aligned. This time the impeller was shot - no missing blades but was obviously running dry. Taking a closer look - I am wondering if the erosion on the housing that separates the raw water intake from the exhaust is allowing air/exhaust to be sucked in and not water.
I was hoping to make it through this year then replace next year with SE 116. Here is a picture:
Re: Impeller not pumping - possible air leak(with picture)
Ayuh,... That's a distint possibility,... That's a Nasty lookin' case....
Bt Doctur
I`d agree with Bondo, case is finished .
SC_Regal
That's what I was afraid of - is it possible to fix/replace or should I just go ahead and order a new outdrive from Sterndrive Engineering?
Ayuh,... That'd probably be Cheaper in the Long Haul,....
You could Try butterin' it up with epoxy,..... But,....:rolleyes:
SC_Regal
Bond-O
your user name (and your post) were an inspiration.
I used JB Weld marine product (not quite bondo) and "repaired" the area of corrosion and smoothed the surface where the gasket sits. Just ran great on the muffs and in a tank. The repair felt very solid. I would think that it is a low pressure area and any force would be pushing the repair toward the rubber block which would lend some support.
I still plan on getting a new outdrive, but I hope this buys me some time so I can iron out some issues/logistics with my dock and floating lift so I don't repeat the mistakes which led to the condition of my current drive.
Thanks - this site should be required before you buy a boat
Ayuh,.... Good Luck man,....;)
edit; benchmark, 29,000 posts
SC_Regal
glad I could be a little part of history - I'll let you know how it goes
