I have a 79 Johnson 6hp as a kicker. I recently overhauled the lower unit and changed out the waterpump impeller (yes it is installed correctly
). <br />Is this engine supposed to give a light trickle out of the telltail when idling and a low strength stream when WOT? I'm used to a somewhat powerful stream at all times but I'm used to working with larger engines. I've checked for obvious blockage but have found none.<br />Is this stream normal or should I dismantle the whole thing and check the entire cooling system?<br /><br />Thanks,<br />Nav
