Fordiesel69
- Sep 18, 2009
- 1,146
I know this is dumb, but the old impeller vanes were all bent in the same direction. Upon putting the new impeller into the housing, I was unable to get all the vanes in the same direction. Will this be a problem? Or when it gets turning they will all bend the right way.
Also on my alpha one, the drive slide back into the coupler VERY easy and I did not have to hammer or use the nuts to force it in. On my sea ray with the MR drive it went in all but 1/2 inch, not quite enough to get the nuts started, I had to use a block of wood and hammer to get it in far enough to get the nuts started. Any reason for this?
