I have a 1997 Powerquest 454 Mag w/ a Bravo One Stern Drive. I guess Im a little confused on the water impeller placement......are there two different water impellers in the boat? One being at the bottom half of the stern drive, the other located at the base of the engine itself, inside the seawater pump. Is this true? I see the water impeller located here in this photo (http://www.sterndrive.info/sterndriveparts/id21.html).<br /> <br />I also have a repair manual for the 454 Mag itself, which shows the water pump and impeller located near the fuel pump itself. I'm not sure which one needs replacing...I know one of them is bad for sure...engine overheats majorly....It would be of great help if you could clear this up for me. Thanks!<br /> <br />Scott Gibson<br />Detroit MI
